RaceCapture-Pro MK4S Sensors
GM-Style
- Thread Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
- Thread Size : 3/8" NPT
- Cable length : N/A
- Body Material : Copper
- Pigtail :Pico 5616pt
- Body Material : Brass
Delphi-Style
- Voltage supply : 5V
Pressure Sensors
Fluid Pressure
- Cable length : 2 Meter
- Mfg / Prt : AEM 30-2131-150
- Mfg / Prt : 12223861 (GM)
- Output : 0.2 to 4.9 V
- Use : An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems.
Pulse/Speed/RPM Sensors
- Mfg / Prt : ASL_COILX
Wheel Speed / Gear speed
- Mfg / Prt : Hamlin 55505
- Mfg / Prt : Cherry GS100701
- Thread Size : 15/32-32
- Supply Voltage : 5 to 24 V
- Supply Current : 3 to 6 mA
- Body Material : Aluminum
- Output current : 25mA max
Distance Sensors
Ride Height
[ Sharp GP2D12 : IR Range Sensor]
- Mfg / Prt : Sharp GP2D12
- Detecting Range : 10-80cm
