RaceCapture-Pro MK4S Sensors
Pullup Resistor
Use a 2.2K ohm pull-up resistor for high resistance ECU style sensors, such as the temperature sensors in supported list
Sensor Ground
  • Thread Size : 1/8″ NPT
  • Cable length : 1 Meter
  • Voltage supply : 3-5V
  • Thread Size : 3/8" NPT
  • Cable length : N/A
  • Body Material : Copper
  • Pigtail :Pico 5616pt
  • Body Material : Brass
  • Voltage supply : 5V
Pressure Sensors
  • Cable length : 2 Meter
  • Mfg / Prt : AEM 30-2131-150
  • Mfg / Prt : 12223861 (GM)
  • Output : 0.2 to 4.9 V
  • Use : An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems.
Pulse/Speed/RPM Sensors
  • Power
  • Ground
  • Signal Output
Wiring the Speed Sensor
Recommended RPM Sensor
  • Mfg / Prt : ASL_COILX
  • Mfg / Prt : Hamlin 55505
  • Mfg / Prt : Cherry GS100701
  • Thread Size : 15/32-32
  • Supply Voltage : 5 to 24 V
  • Supply Current : 3 to 6 mA
  • Body Material : Aluminum
  • Output current : 25mA max
Distance Sensors
  • Cable : 2 meter cable
  • Range : 10K ohm range
  • Mfg / Prt : Sharp GP2D12
  • Detecting Range : 10-80cm
  • Mfg / Prt : BMW 37140141444
  • Pigtail : 61138383300
  • Voltage Supply : 5V
[ KA Sensors RHL3 : Laser Ride Height Sensor] The specification are as follows.
Step To Calibrate :
Create Calibration Table:
Angle/Rotation Sensors
Throttle Position (TPS)
  • Mfg/Prt : Ford / SMP TH45
  • Pigtail : Pico 5752PT
  • Supply Voltage : 5V
Air / Fuel Ratio Sensors
  • Mfg/Prt : Texense LSU 4.9
  • Pigtail : Built-in wiring
Wiring Analog Sensors
Calibrating Analog Sensors
Linear Sensors
Example : 150 PSI pressure sensor
  • 0.5 v = 0 PSI
  • 4.5 v = 150 PSI
Curved Sensors
Example : Extended range temperature sensor with 5v reference and 2.2K pullup resistor
  • 0.4 v = 302 F
  • 0.87 v = 239 F
  • 1.88 v = 176 F
  • 3.2 v = 122 F
  • 4.72 v = 32 F
Types of Sensors
