RaceCapture-Pro MK4S Sensors
Pullup Resistor
Sensor Ground
- Thread Size : 1/8″ NPT
- Cable length : 1 Meter
- Voltage supply : 3-5V
- Thread Size : 3/8" NPT
- Cable length : N/A
- Body Material : Copper
- Pigtail :Pico 5616pt
- Body Material : Brass
- Voltage supply : 5V
Pressure Sensors
- Cable length : 2 Meter
- Mfg / Prt : AEM 30-2131-150
- Mfg / Prt : 12223861 (GM)
- Output : 0.2 to 4.9 V
- Use : An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems.
Pulse/Speed/RPM Sensors
- Power
- Ground
- Signal Output
Wiring the Speed Sensor
Recommended RPM Sensor
- Mfg / Prt : ASL_COILX
- Mfg / Prt : Hamlin 55505
- Mfg / Prt : Cherry GS100701
- Thread Size : 15/32-32
- Supply Voltage : 5 to 24 V
- Supply Current : 3 to 6 mA
- Body Material : Aluminum
- Output current : 25mA max
Distance Sensors
[ASL_STRING_POT_M8 : 500mm string potentiometer sensor]
- Cable : 2 meter cable
- Range : 10K ohm range
[ Sharp GP2D12 : IR Range Sensor]
- Mfg / Prt : Sharp GP2D12
- Detecting Range : 10-80cm
[ BMW 37140141444 : Height Level Sensor]
- Mfg / Prt : BMW 37140141444
- Pigtail : 61138383300
- Voltage Supply : 5V
[ KA Sensors RHL3 : Laser Ride Height Sensor] The specification are as follows.
Step To Calibrate :
Create Calibration Table:
Angle/Rotation Sensors
[Ford / SMP TH45 : Throttle Position Sensor]
- Mfg/Prt : Ford / SMP TH45
- Pigtail : Pico 5752PT
- Supply Voltage : 5V
Air & Fuel Ratio/ Level Sensor
Recommended Air / Fuel Ratio Sensor
[Texense LSU 4.9 : Air / Fuel Ratio Sensors]
- Mfg/Prt : Texense LSU 4.9
- Pigtail : Built-in wiring
Wiring Analog Sensors
Calibrating Analog Sensors
Linear Sensors
Example : 150 PSI pressure sensor
- 0.5 v = 0 PSI
- 4.5 v = 150 PSI
Curved Sensors
Example : Extended range temperature sensor with 5v reference and 2.2K pullup resistor
- 0.4 v = 302 F
- 0.87 v = 239 F
- 1.88 v = 176 F
- 3.2 v = 122 F
- 4.72 v = 32 F
Fuel Level Sensors
Calibration With the fuel at different levels, measure and note the voltage present at the RaceCapture analog input for different fuel levels:
- Empty (0%)
- 1/4 (25%)
- 1/2 (50%)
- 3/4 (75%)
- Full (100%)
Set up the Analog Channel
- Choose an available analog input for your Fuel Level channel, then select the basic fuel level preset by selecting FuelLevel in the dropdown list. (This pre-sets the units (%), logging precision and min / max values. You can edit this by pressing the gear button next to the channel name
- Set the sample rate to 1Hz.
