RaceCapture on Raspberry Pi
Revision as of 14:55, 21 February 2024 by Brentp (talk | contribs) (→Launch the app)
Benefits
Compatibility
Experimental!
Hardware Selection
Raspberry Pi
Display
Enclosure
Installed on Dashboard
Power Supply
Suggested Power Supplies
Powering RaceCapture
Heat sinking
Installing Raspberry Pi OS
We currently recommend Raspberry Pi OS Lite, Debian Version 12 (bookworm) and require a 64bit version for app versions 2.9.0 and newer.
Once you've created your image, boot up your Raspberry Pi and follow the prompts to set your keyboard language and create a username and password.
You should now be able to login as that user and will be greeted with a command prompt like `user@raspberrypi:~ $`
Wifi Setup
Timezone
It is advisable to set the system's timezone before proceeding. This is also accomplished by using raspi-config which is run with the command `sudo raspi-config`. If you are also setting up Wifi you can configure your timezone at the same time you are configuring Wifi.
The timezone setting is configured in `5 Localization Options`->`L2 Timezone`. This will allow you to set the timezone by first selecting your region and a major city in your timezone. When done setting the timezone you can back out of raspi-config by hitting escape until you are back at the command prompt.
Checking your network
At this point it is good to make sure your Raspberry Pi is connected to your network. Without this none of the remaining steps will be successful.
user@raspberrypi:~ $ hostname -I
192.168.1.183 2601:601:d07f:c107:dfb6:823:b21d:6dff
Updating to latest packages
sudo apt update
sudo apt dist-upgrade
RaceCapture App Installation
If you want a more custom installation, such as running in a full Desktop environment, manual instructions are also provided.
Via Installation Script
From a command prompt simply run
sudo sh -c "curl -sL bit.ly/3yTbPyZ | bash"
Configuration Options
The installation script prompts for the following:
Auto Login
  • Whether to enable auto login upon startup, if not already enabled (Recommendation: Yes)
    • This allows the RPi to login as the current user and launch the RaceCapture App upon startup of your Raspberry Pi. Without this you will need to login every time your Raspberry Pi is powered up.
RPi3 Official Display Support
  • If running an RPi3, whether you are running an Official RPi display.
    • Only select yes if you are using a RPi3 with an Official RPi display plugged into the LCD/MIPI connector on the board. Enabling this will disable HDMI support as the RPi3 doesn't appear to automatically detect LCD screens properly.
Installation Type
  • Which type of installation you want, Framebuffer (traditional installation), or X11 which enables the option of VNC support
  • If X11 was chosen:
    • Whether to enable VNC and if so prompts for entering a VNC password
App Features
  • Watchdog: Enables automatically restarting the RaceCapture App should it crash/exit unexpectedly
  • Cursor: Enables a visual mouse pointer (Not recommended for touchscreens)
  • Keyboard: Enables an onscreen virtual keyboard for touch screens
Extra Features
  • Wifi Auto Reconnect: Enables a script that detects if your wifi connection is down and attempts to reconnect
  • USB Automounting: Enables automatic mounting of USB thumbdrives under /media/usb#, useful for exporting session data or saving configs off the device
  • GPIO Reboot/Shutdown: Enables the ability to add a button or switch between GPIO21 and a ground pin, with a short press causing a reboot and a long press causing a graceful shutdown
Post Configuration Steps
Next it will unpack the App into /opt/racecapture, prompting you to overwrite and existing installation if one exists.
Finally, the script will modify some files, .bashrc and .xinitrc for X11 installations, so that the Race Capture app launches upon login.
Manual Installation
Install package dependencies
sudo apt install mesa-utils libgles2 libegl1-mesa libegl-mesa0 mtdev-tools
User Permissions
Ensure that the user is in the dialout, render, video and input groups. It appears these are added by default but to be sure you should run:
sudo adduser $USER render
sudo adduser $USER video
sudo adduser $USER input
sudo adduser $USER dialout
cd /opt
sudo wget <package URL>
Extract the package
Launch the app
/opt/racecapture/run_racecapture_rpi.sh
Launching with Watchdog
killall -9 run_racecapture
Enabling on screen keyboard
Edit the kivy config.ini file with:
sudo nano ~/.kivy/config.ini
and update the keyboard_mode line with:
keyboard_mode = multi
Powering up
Installed via Script
Manual Installation
See #Launch_the_app
Connection and usage
Extra Features
Hardwire buttons
    • N : to indicate 'No"
Additional Tips
Logfiles for troubleshooting can be found at
/home/pi
