AIM SmartyCam CAN
Connecting to the AIM system
| AIM cable connection mapping | ||||||
| Connection | AIM Pin (Binder 702) | RaceCapture/Pro Pin (EIA-T568B Ethernet cable) | ||||
| CAN High | 1 (White) | 2 (Orange) | ||||
| CAN Low | 4 (Blue) | 3 (Green / White) | ||||
| Ground | 2 (Brown) | 1 (Orange / White) | ||||
| VBExt | 3 | N/C (Do not connect) | ||||
Note
- RaceCapture/Pro provides a 12v input pin (Pin 8) on the RJ45 connector, which has a common connection to the 12v input of the RaceCapture/Pro terminal block.
- This pin is rated at 1A max. We do not recommend using this pin to supply power to the AIM Smarty CAM.
Available Channels
| BMW E46 (including M3) | ||||||
| AIM Channel Name | RaceCapture channel name | |||||
| RPM | RPM | |||||
| Gear | Gear | |||||
| WaterTemp | EngineTemp | |||||
| Oil Press | OilPress | |||||
| Oil Temp | OilTemp | |||||
| Throttle Position | TPS | |||||
| Head Temp | HeadTemp | |||||
| Exhaust Temp | EGT | |||||
| Brake Pos (channel 1) | BrakePos | |||||
| Clutch Pos (channel 2) | Clutch | |||||
| Brake Press (channel 3) | Brake | |||||
| Steer Position (channel 4) | Steering | |||||
| Lambda (channel 5) | Lambda | |||||
| FuelLevel | FuelLevel | |||||
Integration Cable
Build your own
Get a pre-made cable
AIM Integration configuration
Direct CAN channel Mapping
Instructions:
- Save any existing channel configuration, such as your analog sensors, as this starter configuration will overwrite your current configuration.
- Unzip the downloaded AIM SmartyCAM configuration and extract the .rcp file.
- Connect the RaceCapture app to your RaceCapture system
- Go to Setup, and press Open to open the unzipped configuration file.
- Press Write to write the configuration to your RaceCapture system.
- Switch to the Dashboard view to monitor and verify the AIM SmartyCAM channels.
Important Note
- If you are converting from the Lua script integration to direct CAN mapping, be sure to completely remove your Lua script mapping by erasing the Lua scripting window and writing the configuration back to RaceCapture.
- Full guide on CAN Mapping here.
