MJLJ V4 vehicle installation guide
Revision as of 01:19, 16 September 2008 by Brentp (talk | contribs) (→Crank timing wheel and sensor installation: Clarified timing wheel installation instructions)
Parts you will need
  • EDIS module: Acquire an EDIS Ignition module matching your engine type- EDIS-4 for 4 cylinder engines; EDIS-8 for 8 cylinders; EDIS-6 for 6 cylinders
EDIS Donor vehicles
EDIS-4 Ford Escort 1990-99 US
Ford Fiesta 1990-93 Europe
Ford Escort 1990-93 Europe
Ford Sierra 1990-93 Europe
Ford Mondeo 1990-93 Europe
Ford Explorer 1990-97 US
Mazda Navajo 1990-97 US
Ford Aerostar 1990-97 US
Lincoln Town Car 1990-97 US
Ford Thunderbird 1990-97 US
Mercury Cougar 1990-97 US
Ford Mustang 5.0 1990-97 US
EDIS installation
Sensor Position
EDIS-4 90 9
EDIS-6 60 6
EDIS-8 50 5
  1. Mount the sensor in any convenient way that simplifies bracket design and accomodates mounting points on the engine block.
  3. Position the timing wheel onto the crank pulley with the missing tooth aligned with the sensor.
  5. mark this final location of the sensor wheel onto the crank pulley- then weld or bolt into place as appropriate.
Megajolt Lite Jr. Wiring
Minimal Wiring for operation
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Smiths RVI type tachometers
Enabling Option Switch
Rev Limit control
Hard Rev Limit
Soft Rev Limit
Auxiliary Input
Analog input source
Hardware Modification
File:Mjlj v4 0-5v aux in hardware mod.png
MJLJ Operation
Verifying MJLJ operation
If the advance does not change, or appears jittery or unstable, see the Troubleshooting Section for additional help.
