  • Local video recording
System Overview
Cost
How hard is it to setup?
  • Typing computer commands
  • Plugging in cables
  • Editing configuration files
Production State
A demonstration
Experimental
Parts you will need
Compatible Systems
Rendering/Streaming computer
Recommended
Alternatives
  • Look for these options:
Candidates
12v DC to DC converter
  • Tips:
Recommended
  • Tips:
Cameras
Recommended Camera Kit
Autosport Labs will soon provide a camera kit that provides high quality imaging, a compact and ruggedized IP65 form-factor, and the perfect 110 degree field of view.
Assembling the Camera Kit
Using the supplied hardware, insert the nut into the camera clamp using a pair of small pliers. Then, use the included screw to clamp the camera to the mount.
Then, assemble the camera clamp into ball and socket windshield mount, or the GoPro mount. (1 of each style is included in the kit)
Ball and Socket windshield mount
GoPro style mount
Alternatives
  • Tips:
Microphone
  • Candidates:
Using the Microphone included with the kit
The kit provides a USB microphone with good audio quality.
Display Emulator
Hotspot/Router
Setup
Install ubuntu 22 LTS
OS configuration options
    • Select Login Automatically
    • When prompted for your account's username, make sure you specify a password. This will allow you to easily switch between streaming mode and maintenance mode.
Disable keyring popup
  • Notes
Run the installer
sudo apt install curl
Reboot
Edit RaceCapture settings
App Preferences
  • set Fullscreen -> ON
  • Turn off Session Recording
Dashboard Preferences
  • Turn off Pit stop timer
  • Turn off pit-to-car alerts
Plug in camera(s)
Plug in USB microphone
  • Plug USB microphone into a USB port.
Note: if using the Beelink, plug into one of the USB ports on the rear of the system.
Connect RaceCapture
Via USB (overall best option)
Via WiFi
Configure as Client
Create a test dashboard
Exiting the RaceCapture app
At the login screen, select your username and press the small gear icon in the lower right to select the Ubuntu desktop.
Video Streaming / recording
Example default video-config.ini file
[capture]
# specify the id number of the audio device, or the name of the audio
# device as reported by arecord -l
audio_device=USB Audio Device
[local_recording]
video_dir=$HOME/Videos
segment_length_sec=60
[streaming]
# replace <your-streaming-key> with the actual key provided by youtube
streaming_url=rtmp://a.rtmp.youtube.com/live2/<your-streaming-key>
# bitrate in kbps
bitrate=4500
Video Streaming
Streaming Key / URL
Bitrate
Specified in kbps. Specify a lower number to conserve bandwidth, at the cost of quality.
[streaming]
bitrate=4500
  • Note: Typical numbers are 2000 - 6000
Local recording
If video_dir is set and points to a valid directory, local video recording will also be enabled.
After the session is complete, a full video can be made by using commonly available software to assemble all of the files.
[local_recording]
Notes
  • Configure video_dir to the location where you want to save your video files.
  • Configure segment_length_sec for the desired segment length size. If not specified, the default is 60 seconds Note, keep this value reasonably short - sudden power loss will result in corruption in the last written file.
Microphone
Specifying microphone by device name (recommended)
To configure your USB microphone by device name, open a terminal window on the streamer and issue this command:
arecord -l
Example output (yours may be different)
streamer@streamer:~/logs$ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: Generic_1 [HD-Audio Generic], device 0: ALC897 Analog [ALC897 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: Generic_1 [HD-Audio Generic], device 2: ALC897 Alt Analog [ALC897 Alt Analog]
  Subdevices: 1/1
card 2: acp [acp], device 0: DMIC capture dmic-hifi-0 []
  Subdevices: 1/1
card 3: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
  Subdevices: 0/1
[capture]
audio_device=USB PnP Sound Device
  • Note: the default video-config.ini is pre-configured as USB PnP Sound Device, which matches the USB microphone we provide in our pre-made kits.
Specifying microphone by device ID (alternative, not recommended)
You can also specify the numeric ID of the audio device. In the above example, the ID is 3
[capture]
audio_device=3
  • Note: This is not normally recommended because the order of the USB IDs may change every time the streamer boots up.
First Test
Maintenance/Troubleshooting
Open a terminal window
Log out
Inspecting Logfiles
Log files are located in the logs directory under the user's home directory. Log files are named with the date they were created.
Video streamer log file
The log files for the video streamer agent have information about the video streamer's connection and activity. You can open it to see any helpful error messages regarding streaming.
RaceCapture log file
The RaceCapture log file will have potentially useful information for debugging the operation of the RaceCapture app.
Extras
Mount for Beelink micro PC
