MJLJ V4 kit assembly guide
Precautions
Surface mount Components
The soldering portion of this kit was NOT designed for beginners! The Megajolt Lite Jr. makes extensive use of surface mount components. Hand-soldering SMT components requires advanced soldering skills and a steady hand. Individual parts are tiny, and are therefore easy to overheat and damage.
Before you Begin
Familiarize
Do not lose parts
- Leave the parts in their bags and protective tape: Remove them just before soldering.
- Tiny flying parts: Be careful when extracting the parts from the tape- they can go flying if the protective tape is removed too quickly. Also, ensure you have a good grip on the part with your tweezers- a missed tweezer grab can send the part flying.
- Work surfaces and floor: Work in a clean and open area, preferably with hard floors: if a part falls off the bench or flies away from a missed tweezer grab, it will be easier to find.
Lighting
Note part orientation
Do not overheat
Assembling the kit
Tools you will need
- A fine-tipped, low wattage soldering iron is necessary for precision work.
- Probably the best tool - a cross-action set of tweezers. This tool is normally closed, allowing you to hold parts with a relaxed grip and reduced tremors.
- Solder wick. Too much solder and you'll create ugly blobs and solder spikes. use this to clean up your joints by drawing away excess solder.
- A magnifying glass, preferably illuminated, is useful for identifying package markings and inspecting solder joints.
Parts Inventory
| Part | Type | Value | Photo |
| R3 | Resistor | 1K |
| C11 | Capacitor | 0.1uF |
| C12 | Capacitor | 0.001uF |
| C13 | Capacitor | 0.22uF |
| C14 | Capacitor | 15uf |
| D5 | Diode | Schottky Diode | |
| L1 | Inductor | 1uH |
| R4 | Resistor | 270 ohm |
| C8,C9 | Capacitor | 0.1uF |
| PS1 | Sensor | MPX4250ap |
| Fastener | Zip Tie |
Surface Mount Parts
Power supply Circuit
Prepare solder pads
TIP: It's important you only add solder to one component pad: if more than one pad is prepared, it will be extremely difficult to install the part flush to the board!
Components
- U3: LM2937-5.0 Voltage regulator. Heat up the prepared solder pad and slide the part into position. Once tacked into place, ensure the part is flush against the board. Solder the remaining pins, including the large tab!
- D1,D2,D3: 1A 400V diode. Note stripe orientation: The silk-screened arrow on the PC board points to the side with the stripe.
- D4: 12V Zener diode. Note stripe orientation: The silk-screened stripe on the PC board matches the diode's stripe.
The stripe on the diodes can be hard to see. If you have difficulty identifying them, increase the lighting- bright light is essential. Also try tilting the device to reduce reflections. DO NOT install the part until you are confident the orientation is correct!!
- C2: 33uF tantalum. Note stripe orientation: ensure it matches stripe on PC Board.
- C1: Most kit builders will be working with the board on a flat surface- if so, it's best you install C1 along with the other through-hole components, after all surface mount components are installed.
- R9: 680 ohm resistor
Testing Voltages
- Power supply components:
Apply power to the Molex pads shown in the image using a low current, 9 - 12v power supply source. A 9V battery is ideal for testing.
Verify +5v at the test point. if the test point is covered with green solder mask, you can test on the adjacent pads on D1 or R9.
- U1: Verify +5v across the Vdd, Vss pins of U1
- IC1: Verify approximately +V-Supply (about .6 volts lower than +V-Supply) across the IC1 CD+ and Gnd pins
- U2: Verify +5v across Vcc and GND pins of U2
- QG1: Verify +5v across Vcc and GND of oscillator QG1
- PS1: If optioned for MAP, Verify +5v across PWR and GND pins of the MPX4250a
Main Circuit
Prepare Solder Pads
Components
- R1,R7: 100 ohm resistor (resistor package marked 101)
- R2,R8: 1K resistor (marked 1001)
- R5,R6: 2.2K resistor (marked 222)
- D6,D7: Schottky diode (strip of two diodes, SOD-123 package
Note Polarity: Stripe on diode package towards bottom edge of board. - C15: 0.001uF capacitor (strip of one capacitor, RED stripe on tape)
- C16: 0.22uF capacitor (strip of one capacitor, VIOLET stripe on tape)
- C4,C6,C7,C10,C5,C3: 0.1uF capacitor (strip of 6 capacitors, ORANGE stripe on tape)
MAP sensor option
- C9,C8: 0.1uF capacitor (strip of 2 capacitors, ORANGE stripe on tape)
- R4: 270 ohm resistor (resistor package marked 271)
TPS option
- C12: 0.001uF capacitor (strip of one capacitor, RED stripe on tape)
- R3: 1K resistor (resistor package marked 1001)
- C13: 0.22uF capacitor (strip of one capacitor, VIOLET stripe on tape)
- D5: Schottky Diode (strip of one diode, SOD-123 package
) Note polarity: stripe on diode package oriented towards bottom of board. - C11: 0.1uF capacitor (strip of one capacitor, ORANGE stripe on tape)
- C14: 15uF capacitor (grey tantalum package) Note polarity Match stripe on component with stripe on board.
- L1: 1uH inductor (strip of one inductor, 1210 package:
Testing Voltages
Before continuing, repeat the voltage testing steps outlined in the power supply build section.
Through Hole Parts
IMPORTANT: It is extremely important you install the through-hole components with the correct orientation! De-soldering a backwards-installed component is extremely difficult and will likely damage the board.
GET IT RIGHT THE FIRST TIME!
Install Components
- U1 16 pin DIP socket: Note notch orientation. Ensure socket is flush against board.
- IC1 16 pin DIP Socket: Note notch orientation
- U2: MAX232A (or equivalent) Note notch orientation
TIP: for the sockets and U2, solder only one pin and check for part flatness against board. You may need to re-heat the pad while squeezing the part against the board. Once you are satisfied, you can solder the rest of the pins.
- C1: 33uF electrolytic capacitor. Note orientation: (-) stripe on capacitor must be opposite of + mark on board; towards molex connector
- LED1: Right angle green LED. ensure this is completely flush against board as it must align with hole in case end plate.
- QG1: 16MHz oscillator. Note orientation of package- sharp corner must match sharp corner on board silkscreen.
- X1: RJ11 Modular Jack. Snap connector into place and verify connector is square against board before soldering, as it must align with hole in case end plate.
- X2: 16 pin right angle molex connector. Snap into place and ensure connector is flat and square against board before soldering.
TIP: solder pins on opposite corners, and re-check the connector is flat and square against the board. If not perfect, re-heat solder near the affected corner and correct the connector's position.
MAP Sensor Option
TIP: Use a small pair of pliers to tighten the zip tie: The zip tie should be flat and square around the board with no slack and the sensor should be reasonably difficult to shift side-side.
Testing Voltages
- U1
- U2
- IC1
- QG1
- PS1
Installing ICs
- U1: Install MJLJ V4 Processor Freescale MC908QB8. Note notch orientation
- IC1: Install ULN2003 transistor array Note notch orientation
Final Inspection
Solder joints
Part placement
- Ensure all through hole components are flush.
- Re-check part orientations: polarity on electrolytic and tantalum capacitor, orientation on diodes, and orientation on ICs and oscillator.
Additional Options
Hard Rev Limiter Module
Enclosure installation
Testing
Verification on the bench
Next Steps
