RaceCapture/Pro MK1 firmware upgrade
ROM bootloader
Prerequisite
- Windows, Linux: download from Atmel's web site Direct download link
- Linux alternative: Linux4SAM
Remove board from enclosure
Load Factory ROM Bootloader
- Locate the 'test' button on the circuit board. If there is no test button installed, bridge the pads where the test button would be installed with a short jumper wire.
- Press the test button (or short the pads), then apply power to the RaceCapture/Pro board using the USB cable. Hold for 20 seconds- this will write back the ROM factory bootloader into flash memory.
- Release the button and disconnect power.
Flash firmware
- Re-apply power using the USB cable.
- In Windows Device Manager you should see the device listed as 'Atmel SAM-BA bootloader'
- If you do not see the board recognized this way, ensure you have the Atmel SAM-BA flash utility correctly installed. If you still have problems, repeat the previous step of loading the factory ROM bootloader.
- Run the SAM-BA flash utility. It should recognize the board.
- Using the SAM-BA flash utility, select the RaceCapture/Pro firmware, which will be a file ending in .bin (e.g. RaceCapturePro-0.0.2.bin)
- Choose the 'flash now' option in the program.
- You should observe the firmware flashing progress in the window. When complete, you can remove power to RaceCapture/Pro.
Verify Firmware
- Re-Apply power to RaceCapture/Pro. In Windows, you should see the RaceCapture/Pro device listed under Ports; note the COM port number assigned. In Linux, you should see a device under /dev/ttyACM0. The 'dmesg' command should have information about the device.
- Using the configuration application, select the appropriate port, connect to the RaceCapture/Pro and verify the current firmware version.
- Restore any previously saved configuration.
Re-assemble RaceCapture/Pro
- Slide the circuit board back in to the enclosure, aligning it with the holes in the end plate. It may be easier in some cases to remove both end plates to enable connectors/LEDs/button to fit into the end plate cut-outs. Ensure the smaller components, like LEDs fit correctly into their respective locations.
- Slide mounting rails into place before installing 2nd end plate. Replace screws.
SD card upgrade
We are developing a more convenient upgrade via SD card. Watch this space for updates.
