RaceCapturePro installation guide
Terminal block connections
Connections Faceing Terminal Block, from left to right
- Ground/Common
- +12v
- Analog/Frequency out 4
- Analog/Frequency out 3
- Analog/Frequency out 2
- Analog/Frequency out 1
- +5V Voltage reference
- Analog input 7
- Analog input 6
- Analog input 5
- Analog input 4
- Analog input 3
- Analog input 2
- Analog input 1
- Frequency/pulse input 3
- Frequency/pulse input 2
- Frequency/pulse input 1
Expansion Port
SD Card Slot
USB Port
The USB port
LED Indicators
- Power LED
- LED1
- LED2
- LED3
Indicates
Pushbutton
Communication Ports
- Port 1
- Port 2
used for GPS module
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
- When configured for input, the channel accepts a 0-5v input.
Reset Pushbutton
Test Pushbutton
JTAG header
