RaceCapturePro installation guide
Revision as of 05:50, 28 September 2012 by Brentp (talk | contribs) (Content for the analog inputs)
Terminal block connections
Connections Faceing Terminal Block, from left to right
  • Ground
  • +12v
  • Analog/Frequency out 4
  • Analog/Frequency out 3
  • Analog/Frequency out 2
  • Analog/Frequency out 1
  • +5V Voltage reference
  • Analog input 7
  • Analog input 6
  • Analog input 5
  • Analog input 4
  • Analog input 3
  • Analog input 2
  • Analog input 1
  • General purpose input/output 3
  • General purpose input/output 2
  • General purpose input/output 1
  • Frequency/pulse input 3
  • Frequency/pulse input 2
  • Frequency/pulse input 1
Power Connection
Analog Inputs
  • Active Sensors/Signals
  • Resistive sensor
When connecting resistive style sensors, like many temperature and pressure sensors, one terminal of the sensor is connected to ground, and the other is connected to the Analog input, with a pullup resistor connected to the +5V Voltage Reference on the terminal block. A 2.2K resistor is recommended for most applications. Our Sensor Breakout Board provides a convenient way to wire up 7 sensors to the RaceCapture/Pro.
Expansion Port
SD Card Slot
USB Port
The USB port
LED Indicators
  • Power LED
  • LED1
  • LED2
  • LED3
Indicates
Pushbutton
Communication Ports
  • Port 1
  • Port 2
used for GPS module
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
  • When configured for input, the channel accepts a 0-5v input.
Reset Pushbutton
Test Pushbutton
JTAG header
