RaceCapturePro TelemetryQuickstart
Unbox
Purchasing SIM Card
- T-Mobile
- AT&T
Installing SIM card
- open telemetry enclosure
- unlatch simcard holder
- insert SIM card
- latch simcard holder in place
- re-assemble case
Connect components
Telemetry Module
- Plug cable in to connectivity expansion port (the port closest to the LEDs)
Connect GPS to RaceCapture
- Connect GPS module to GPS port (port next to the telemetry port)
Connecting Antenna
- Connect antenna to RF port
- Don't overtorque!
- Go to http://www.race-capture.com, click on Signup in the top navigation
- Create your account
- After creating your account you will be prompted to add your device. Do it :)
- Once added you will be given a device id, save this, you'll need it soon.
Install RaceAnalyzer
Configure RaceCapture/Pro
Set channel sample rates
The default sample rates are too high for real-time telemetry, set the following sensors to these recommended values:
- GPS 1Hz -5Hz
- Accelerometer 5Hz
Set device id
Write configuration
- Click the 'Write' button in RaceAnalyzer
- Power cycle RCP (turn off then on again)
Testing
- http://www.amazon.com/Sabrent-Powered-adapter-compatible-HB-USB30/dp/B00BJPRI1Y/ref=sr_1_3?ie=UTF8&qid=1367991516&sr=8-3&keywords=usb+hub+high+power
- http://www.amazon.com/D-Link-DUB-H7-High-Speed-7-Port/dp/B00008VFAF/ref=sr_1_5?ie=UTF8&qid=1367991578&sr=8-5&keywords=usb+hub+high+power
Press the black switch on the front of your RaceCapture/Pro device to start logging. Watch LEDs on telemetry device explain / document LED flashing Press log button Got to race-capture.com/home, look for a new event, click on it
TaDa!
