RaceCapturePro TelemetryQuickstart
Unbox
Purchasing SIM Card
  • T-Mobile
Purchase a "Pay By the Day" SIM card from your local t-mobile dealer. We recommend picking a plan with the 2G/3G unlimited data, which is currently $3 USD/day. The plan is only charged when data is actually used during a 24 hour period. Visit T-Mobile for more details on prepaid plans.
  • AT&T
AT&T is not currently supported; expect support soon in an upcoming firmware version.
Installing SIM card
  • Open telemetry enclosure
Unlatch SIM card holder
Insert SIM card
Insert the SIM card, taking note of the beveled edge. The SIM card can only be inserted in one direction. Telemetry sim chip cover open.jpg
Latch simcard holder in place
Swing the cover closed and slide towards the 'lock' position. take care that the cover is locked on both sides of the holder and it is flush with the board. Telemetry unit sim cover closed.jpg
Re-assemble case
  • You may need to gently press the LEDs down flush against the board in order for them to line up with the holes in the opposite end plate.
Connect components
Telemetry Module
  • Plug cable in to connectivity expansion port (the port closest to the LEDs)
Connecting Antenna
  • Connect antenna to RF port
    • Don't overtorque!
Connect Telemetry module to RaceCapture
  • Connect Telemetry module to connectivity port (port to the right of pushbutton switch)
  • Go to http://www.race-capture.com, click on Signup in the top navigation
  • Create your account
Install RaceAnalyzer
Configure RaceCapture/Pro
Set channel sample rates
The default sample rates are too high for real-time telemetry, set the following sensors to these recommended values:
  • GPS 1Hz -5Hz
  • Accelerometer 5Hz
Set device id
Add your device id that you wrote down when adding your device to race-capture.com to the Telemetry Device Id field under the Logging/Telemetry section: Devicesetup.png
Write configuration
Testing
Watch LEDs on telemetry device explain / document LED flashing Got to race-capture.com/home, look for a new event, click on it
TaDa!
