RaceCapturePro Sensors
GM Style fluid sensors
  • Wells SU109
  • SMP TX3
Pico 5615pt
0.37 212.00
0.51 178.00
1.99 104.0
2.47 72.0
4.24 23.0
  • Wells SU107
  • SMP AX1
Pico 5616pt
AEM Fluid Sensors
Part # Image Mechanical Description Notes Analog Channel Configuration
AEM-30-2012
  • 1/8" NPT
  • Compact form factor is appealing
0.40 302.00
0.87 239.00
1.88 176.0
3.2 122.0
4.72 32.0
Infrared Temperature
Interface modules for these sensors are in research and development
Mfg / Part Image Description Notes
Mylexis MLX90620
Thermocouple Sensors
Pressure Sensors
Oil, fuel Pressure
Mfg / Part # Image Mechanical Description Notes Analog Configuration
AEM 30-2131-150
  • 1/8" NPT
  • 3 pin GM connector
  • Technical Information
Default kit from AEM includes pigtail
Volts Scaled Value (PSI)
0.5 0.0
4.5 150.0
4.5 150.0
4.5 150.0
4.5 150.0
Various
  • 1/8" NPT port
Boost / Vacuum
GM 3.3 bar MAP sensor
  • Sensor: 9373269
  • Pigtail: 88987997
Tire Pressure
Pulse Sensors
Wheel Speed
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Temperature Sensor
Pullup resistor
  • VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
SensorX
