RaceCapturePro Sensors
GM-Style | |||||||||||||||||
Pico 5615pt |
Pico 5616pt |
AEM | |||||||||||||||||
| AEM-30-2012 |
| Mylexis MLX90620 |
3 bar MAP sensor |
| Freescale MXP4250AP |
2.5 bar MAP sensor
| Schrader |
RPM | |||||||||||||||||
| Autosport Labs CoilX | <image> | The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process. | |||||||||||||||
Wheel Speed / Gear speed |
Hall effect speed sensors will require an external 1K pull-up resistor, connected to 5v. This can be wired up near the sensor connection for convenience. | ||||||||||||||||
| Cherry GS102301 | File:Cherry GS102301 gear speed sensor.jpg |
Distance Sensors
Suspension Travel
| Mfg | Description | Pic | Pigtail | Part Numbers | Mechanical | Analog Configuration | Notes |
| Vishay Semiconductors | Specialized Optical Switch | 3-pin connector | Mouser Part #:782-TCND5000 Manufacturer Part #:TCND5000 | Optical Switches, Specialized Reflective Sensor w/PIN Photodiode Out | <link> | Optical distance sensor to be used for pedal travel as well, providing there is a target to sense Link |
Angle Sensors
Steering Angle
Throttle Position
| ASL | Ford type throttle position sensor | see pigtail below | Standard Motors SMP TH45 equivalent | custom | Existing style Throttle position sensor available from AutoSport Labs link | ||
| ASL | Ford type throttle position sensor | 3-pin connector | fits SMP TH45 above | custom | Existing style Throttle position sensor available from AutoSport Labs link |
Brake Position/Pressure
Linear Sensors
Temperature Sensor
Pullup resistor
- GM-style TX3 / SU109 Coolant
- GM-style AX1 / SU107 Air Inlet Temp
- AEM 30-2012 1/8" NPT fluid temperature sensor
- VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
