CoilX
Revision as of 23:03, 15 January 2014 by Brentp (talk | contribs) (Created page with "==Description== Image:CoilX_brd.png The CoilX RPM input module safely interfaces the signal from an ingition coil primary circuit into a clean square wave that can be safely...")
The CoilX RPM input module safely interfaces the signal from an ingition coil primary circuit into a clean square wave that can be safely handled by the RaceCapture/Pro Timer / RPM input.
The module features an optically isolated circuit with additional filtering, to help prevent false triggers.
The 1" x 0.5" compact board is designed to be assembled with heat shrink and bundled in-line with your wiring harness.
Wiring Information
Technical Information
