CoilX
CoilX is a sensor module that safely intercepts the RPM signal from an ignition coil primary circuit into a clean 5v logic-level square wave that can be safely handled by the RaceCapture/Pro Timer / RPM input or other devices.
The module features an optically isolated circuit with additional filtering, to help prevent false triggers.
The 1" x 0.5" compact board is designed to be assembled with heat shrink and bundled in-line with your wiring harness.
Wiring Information
Sensor Connections
Use 22 gauge wire to solder the connections to the CoilX module.
Be sure to clip the soldered wires flush to prevent sharp surfaces.
Slip then module into a length of heat shrink tubing or wrap in electrical tape to insulate the module. You can include this assembly with your wiring harness bundle.
