RaceCapturePro installation guide
Revision as of 08:49, 17 February 2014 by Brentp (talk | contribs) (added LED / sd card connection end)
Power Connection
Analog Inputs 1-7
Active Sensors/Signals
Resistive sensor
Analog/Frequency Outputs 1-4
Frequency/Pulse Input 1-3
TACH SIGNAL NOTES
CoilX Sensor Module
Expansion Port
SD Card Slot
USB Port
LED Indicators
  • Power LED
  • LED1
  • LED2
  • LED3
Pushbutton
Communication Ports
  • Port 1
  • Port 2
Used for GPS module
Shock isolation mounting
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
Reset Pushbutton
Test Pushbutton
JTAG header
