RaceCapture App User's Guide
What's New
Capable of running on Windows, OS X, Linux, iOS and Android, the new RaceCapture app will ultimately combine RaceAnalyzer and the current Mobile app into a unified configuration, dashboard and analysis solution.
With this beta/preview release the RaceCapture app will initially support configuration for RaceCapture/Pro system running the V2 firmware. Dashboard and then Analysis features will follow to make the official application launch.
The latest race track configurations can be automatically downloaded and synchronized from http://www.race-capture.com via the application. If your track is not in the list, email us at [email protected] and we will work to get it added.
Multi-Sector Timing
Separate Start/Finish Lines
Not yet implemented To enable auto-x/rally/hillclimb scenarios we've enabled the ability to define a separate start and finish line.
Predictive Lap Timing
Streamlined Sensor and Channel Configuration
Channel configuration has been simplified where possible with additional default settings that make sense. Automatic channel configuration wizards will help auto-calibrate things like throttle position, fuel level and and steering angle sensors.
CAN bus expansion
OBD2 support
(insert OBD2 configuration here)
Virtual Channels
(link to Lua scripting reference, add code example)
Channel Filtering
Analog, Timer and Accelerometer channels feature an adjustable dampening filter that allows you to smooth out sensor readings as needed. Examples of this use:
- Filtering accelerometer readings for rough environments
- Averaging fuel level readings to compensate for fuel tank slosh
Channel Customization
The concept of a channel has been formalized into a set of universal system level channels where min/max and unit labels can be customized. Additionally, user-defined channels can be defined for special purpose channels.
Upcoming
Dashboard
- Multi-gauge dashboard view
Analysis
- Line charts showing channels over distance, with the ability to combine multiple channels into a single chart
- GPS plots showing the line taken in reference to the center line of the track map
- Sector times for each part of the track
Firmware
- Windows: Check under Device Manager for a RaceCapture/Pro device under the Ports section.
- Linux: When plugged in, a CDC-ACM device should show up. Check it by issuing the dmesg command; typically it will be /dev/ttyACM0
Application
Install the beta RaceCapture app after downloading the setup package from the downloads section.
- OS X: experimental support - USB interface for RaceCapture/Pro does not yet work.
- Android: under development
- iOS: under development
Running
Editing Configuration
