EDIS installation
Wiring notes and guidelines
Installing the MJLJ
Interfacing to Tachometers
The four User defined outputs provided by the MJLJ can be set to trigger on either RPM or Load thresholds. The separate 'shift light' output triggers only on RPM, but otherwise behaves identically to the user outputs.
Rev Limit control
The ford EDIS system offers no direct ability to disable the ignition coils in an over-rev condition. The indirect way to enable this is through an external circuit that disables power to the ignition coils.
The MJLJ offers an output that triggers on the configured rev-limit. An additional feature of the Rev Limit functionality is the ignition advance automatically goes to zero 100 RPMs before the configured hard rev-limit, offering a softer approach to the hard limit.
Current approaches involve either using a mechanical relay to cut power to the coils, or tie the coil (-) to +12V through a current limiting resistor, suppressing spark by preventing the sudden collapse of the coil's magnetic field.
