EDIS installation
Wiring notes and guidelines
Installing the MJLJ
Interfacing to Tachometers
The four User defined outputs provided by the MJLJ can be set to trigger on either RPM or Load thresholds. The separate 'shift light' output triggers only on RPM, but otherwise behaves identically to the user outputs.
Rev Limit control
