Revision as of 16:10, 24 March 2007 by Brentp (talk | contribs) (→Parts you will need: added blurb on additiona parts needed)
Parts you will need
  • EDIS module matching your engine type: EDIS-8 for 8 cylinder, EDIS-6 for 6 cylinder, EDIS-4 for 4 cylinder)
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
With the Engine at TDC for cylinder #1, the sensor should be positioned 'N' degrees before the missing tooth. Make sure you take into account the rotation of the engine: clockwise or counter-clockwise, when determining your sensor mounting.
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
Installing the MJLJ
Interfacing to Tachometers
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
