RaceCapturePro2 QuickStart
Revision as of 23:50, 11 December 2014 by Brentp (talk | contribs) (→Quick Start)
Prerequisites
  • Download and install the app (Windows only currently): RaceCapture App v1.0.0
    • Note for Windows 8 users - These drivers are unsigned. We are working on creating a signed driver set, but in the meantime you will need to disable the driver signing requirement for Windows 8. Instructions
Quick Start
  1. Attach GPS and Telemetry (if purchased) to RaceCapture/Pro
  5. Open the RaceCapture application.
  6. Click on 'Dashboard'
  7. Click on the bottom right arrow three times, which will display the digital dash. You should see the Utc and Interval channels changing, which means data is being transmitted over USB.
