CAN Bus logger
The following script will output all CAN bus messages to the RaceCapture/Pro logfile.
After writing the script, you can see the output in the log monitor window, or you can connect to the serial console directly using a terminal program like Hyperterminal, RealTerm, minicom or similar.
--onTick() will be called at 10Hz. --may need to raise if CAN messages are being missed. setTickRate(10) --500K baud. set your baud rate here. initCAN(0, 500000) --this function drains all pending CAN messages --and outputs messages to the log function outputCAN() repeat id, ext, data = rxCAN(0, 100) if id ~= nil then print(id ..': ') for i = 1,#data do print(data[i] ..' ') end println() end until id == nil end function onTick() outputCAN() end
