AIM CAN
MyChron 4
MyChron 4 research is underway.
MyChron 3
This section documents how to control an AIM Mychron3 Dash display, using a RaceCapture/Pro telemetry system unit via LUA scripting. The following information is a sum up of reverse engineering findings by Jean-Sebastien Stoezel documented here. Examples of LUA implementation of the the different packets documented on the Mychron 3 Hack page are provided below.
Wiring / Connection
TODO: show wiring and connection information between RaceCapture/Pro and Mychron3
CAN Bus Initialization
The AIM Mychron3 requires a CAN bus rate of 1Mb/s, in standard form (11 bit identifiers). The following code example initializes the CAN bus channel at 1Mb/s.
initCAN(2, 1000000)
function onTick() local rpm = getTimerRpm(0) local speedmph = getGpsSpeed() -- Assume the gear is calculated and stored in a virtual channel. -- Refer to LUA scripting example to calculate the gear based on speed and RPM local gear = getChannel(gearId) local msg = {rpm % 256, rpm / 256, (speedmph % 16) % 256, (speedmph / 16) / 256, 0, 0, gear, 0} txCAN(0, 1025, 0, msg) end
function onTick() -- Assume different temperature values are connected to different sensors local temp1 = getAnalog(0) local temp2 = getAnalog(1) local temp3 = getAnalog(2) local temp4 = getAnalog(3) local msg = {temp1 % 256, temp1 / 256, temp2 % 256, temp2 / 256, temp3 % 256, temp3 / 256, temp4 % 4, temp4 / 256} txCAN(0, 1026, 0, msg) end
function onTick() local shiftLeds = 0 local rpm = getTimerRpm(0) if rpm > 5000 then shiftLeds = shiftLeds + 1 end if rpm > 6000 then shiftLeds = shiftLeds + 2 end if rpm > 7000 then shiftLeds = shiftLeds + 4 end if rpm > 7500 then shiftLeds = shiftLeds + 8 end if rpm > 7700 then shiftLeds = shiftLeds + 16 end local msg = {0, 0, 0, 0, 0, 0, shiftLeds, 0} txCAN(0, 1029, 0, msg) end
function onTick() -- Set the RPM range -- Value RPM Range -- 0 25,000 - 0 -- 1 22,000 - 0 -- 2 20,000 - 0 -- 3 16,000 - 0 -- 4 12,000 - 0 -- 5 10,000 - 0 -- 6 8,000 - 0 -- 7 6,000 - 0 -- 8 4,000 - 0 local rpmRange = 6 -- Up to 8000 RPM local msg = {0, rpmRange * 16, 0, 0, 0, 0, 0, 0} txCAN(0, 1030, 0, msg) end
