How To Update Firmware
Revision as of 20:19, 3 January 2015 by Brentp (talk | contribs)
RaceCapture/Pro MK2
Save your configuration
Alternative method
  • You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
RaceCapture/Pro MK1
Note: if you have problems getting RaceCapture/Pro recognized in bootloader mode, try installing the bootloader drivers while the hardware is plugged in to USB in bootloader mode (hold down logging button on RaceCapture/Pro, plug in to USB, then release button)
