RaceCapturePro2 QuickStart
Prerequisites
Quick Start
Running the Application
  2. Click on 'Dashboard'
  4. Once the tracks have been selected, write the updated configuration using the button in the lower left.
Setting up Bluetooth
  1. Complete the Quick Start steps above, leaving RaceCapture/Pro connected to your computer
  2. Connect the Bluetooth module to the inner of the two RaceCapture/Pro ports on the same side the USB cable connects to
  3. Open the Race Capture app
  4. Click on the top left 'Menu' button
  5. Click on 'Configuration'
  6. Click on 'Wireless' in the list of options on the left
  7. Click the toggle to the right of 'Bluetooth'
  8. Click the 'Write Config' button on the bottom left (down array pointing to a RaceCapture/Pro)
Set up Android tablet/phone
Requirements
  • Android 4.4 and higher
  • Quad core 1.6 GHz processor
  • 2 GB RAM, 8 GB flash
  • 7" or 10" screen
Recommended Brands for tablets:
  • Samsung
  • Google Nexus
  • LG
  • Lenovo
Bluetooth pairing
    3. Default password is 1234
  2. Install the Race Capture app on your Android device from the Google Play Store
  3. Open the RaceCapture app. The RaceCapture app will search for the RaceCapturePro device
Verify connectivity
  1. Select the dashboard screen and switch to the raw channels view - you should see values updating in real-time.
Troubleshooting Bluetooth connection issues
  • Ensure RaceCapture/Pro is powered up and the Bluetooth module is plugged in to the inner RJ11 port, located to the right of the front panel push-button
  • Ensure Bluetooth is enabled in the wireless settings of the RaceCapture/Pro configuration
    • Note, you will need to connect via USB to verify this setting
  • Ensure Bluetooth is enabled under the Android Settings
    • On some tablets with a marginal or unstable Bluetooth support, a disable/re-enable of Bluetooth may help
  • Try un-pairing and re-pairing the RaceCapture/Pro Bluetooth device
  • Try re-starting the Android device
Basic Logging of Data
Use a 32GB card or smaller
The filename will end in .log
The logfile is in plain CSV data format.
