MJLJ V3 Operation Guide
Revision as of 18:32, 25 November 2007 by Brentp (talk | contribs) (→Retrieving the Ignition Configuration: Ignition map information)
First time use
Setting the Serial Port
Configuring MAP or TPS
Otherwise, select 'Forced Induction' if your engine is turbocharged or supercharged. This will set the maximum scale to 255KPa (about 21 PSI of boost)
Connecting to the MJLJ
After the COM port has beens et, connect the serial cable to the MJLJ and apply power. If you already have the MJLJ wired into your engine's wiring harness, turn the ignition key to 'on'. If you are testing the MJLJ on the bench, you can simply power the unit with a 9V battery or a suitable 9-15V power supply.
Common connection problems
Timeout reading runtime data
Could not open port
Either:
Ignition Map
Options
Updating the Ignition Configuration
Making the changes permanent
Configuration Options
Configuring TPS
Choosing between Normally Aspirated and Forced Induction
Switchable Ignition maps
Ignition Map View
Runtime View
Tuning View
Data logging
Advanced Topics
