AIM SmartyCam CAN
Under Development
Pictures
CAN database
AIM SmartyCAM CAN protocol
Integration Script
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
fuelId = addChannel("Fuel", 1, 0, 0, 60, "L")
oilPresId = addChannel("OilPressure", 10, 0, 0, 10, 'Bar')
CAN_map = {
[1056] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(tempId, data, 6, 2, 0.1, 0) end,
[1057] = function(data) map_chan(oilTempId, data, 4, 2, 0.1, 0) map_chan(OilPresId, data, 6, 2, 0.01, 0) end,
[1058] = function(data) map_chan(tpsId, data, 2, 1, 1, 0) end ,
[1070] = function(data) map_chan(fuelId, data, 0, 1, 1, 0) end
processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
