RaceCapturePro2 QuickStart
Revision as of 16:00, 2 November 2015 by Brentp (talk | contribs) (added amazon play store info and expanded reccomendations for android tablets)
Prerequisites
Quick Start
Running the Application
  2. Click on 'Dashboard'
  4. Once the tracks have been selected, write the updated configuration using the Rc appwrite config.png button in the lower left.
ProTip: Periodically click the update button Update from cloud.png to pull down the latest set of race track configurations.
Setting up Bluetooth
  • Complete the Quick Start steps above, leaving RaceCapture/Pro connected to your computer
  • Connect the Bluetooth module to the inner of the two RaceCapture/Pro ports on the same side the USB cable connects to
  • Open the Race Capture app
  • Click on the top left 'Menu' button
  • Click on 'Configuration'
  • Click on 'Wireless' in the list of options on the left
  • Click the toggle to the right of 'Bluetooth'
  • Click the 'Write Config' button on the bottom left (down array pointing to a RaceCapture/Pro)
Set up Android tablet/phone
App Download:
Requirements
  • Android 4.4 and higher
  • Quad core 1.6 GHz processor
  • 2 GB RAM, 8 GB flash
  • 7" or 10" screen
Recommended Brands for tablets:
  • Samsung
    • Samsung Galaxy Tab S with AMOLED screen (best performance)
    • Samsung Galaxy Tab Pro 8.4 (good alternative)
    • Samsung Galaxy Tab 4 8.0 inch T337 - good choice with 4G LTE
  • Google Nexus
  • LG
  • Lenovo
  • Amazon Fire Tablet $49.95 edition
Bluetooth pairing
    3. Default password is 1234
  2. Install the Race Capture app on your Android device:
  1. Open the RaceCapture app. The RaceCapture app will search for the RaceCapturePro device
Verify connectivity
  1. Select the dashboard screen and switch to the raw channels view - you should see values updating in real-time.
Troubleshooting Bluetooth connection issues
  • Ensure RaceCapture/Pro is powered up and the Bluetooth module is plugged in to the inner RJ11 port, located to the right of the front panel push-button
  • Ensure Bluetooth is enabled in the wireless settings of the RaceCapture/Pro configuration
    • Note, you will need to connect via USB to verify this setting
  • Ensure Bluetooth is enabled under the Android Settings
    • On some tablets with a marginal or unstable Bluetooth support, a disable/re-enable of Bluetooth may help
  • Try un-pairing and re-pairing the RaceCapture/Pro Bluetooth device
  • Try re-starting the Android device
Basic Logging of Data
    • Use a 32GB card or smaller
    • The filename will end in .log
    • The logfile is in plain CSV data format.
Automatic logging control
