AIM SmartyCam CAN
Connecting to the AIM system
| BMW E46 (including M3) | ||||||
| Connection | AIM Pin | RaceCapture/Pro Pin | ||||
| CAN High | 1 | 2 | ||||
| CAN Low | 4 | 3 | ||||
| Ground | 2 | 1 | ||||
Available Channels
This integration enables the following channels
| AIM Channel Name | RaceCapture channel name | |||||
| RPM | RPM | |||||
| Gear | Gear | |||||
| WaterTemp | EngineTemp | |||||
| Oil Press | OilPress | |||||
| Oil Temp | OilTemp | |||||
| Throttle Position | TPS | |||||
| Head Temp | HeadTemp | |||||
| Exhaust Temp | EGT | |||||
| Brake Pos | BrakePos | |||||
| Clutch Pos | Clutch | |||||
| Brake Press | Brake | |||||
| Steer Position | Steering | |||||
| Lambda | Lambda | |||||
| FuelLevel | FuelLevel | |||||
Integration Cable
Build your own
You can patch up your own cable using a Binder 5 pin series 702 patch cable and splice it with an RJ45 network cable.
Get a pre-made cable
AIM integration cables are available in our online store:
Integration Script
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
CAN_map = {
processCAN(CAN_chan)
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
initCAN(CAN_chan, CAN_baud)
