PE3 CAN
The following script integrates the Performance Electronics PE3 ECU.
Reference Documentation
Supported Channels
This integration supports the following channels:
  • RPM
  • TPS (Throttle Position)
  • InjectorPw (Injector Pulse Width)
  • Ignition (Ignition Advance)
  • Baro (Barometer)
  • MAP (Manifold Absolute Pressure)
  • Lambda
  • IAT (Air inlet temperature)
  • EngineTemp
Connect the PE3 CAN High / CAN Low to the corresponding CAN High / CAN Low on the RaceCapture/Pro CAN 1 channel. See the [CAN_Bus_Integration|CAN integration guide]] for wiring details.
  • Note: The PE3 ECU is already terminated with a 120 ohm resistor.
CAN integration script
Copy and paste this script into the scripting window of RaceCapture/Pro. Ensure any existing script is removed.
-- RaceCapture/Pro CAN mapping for Performance Electronics PE3 ECU
-- see rpmFilter() function
tickRate = 30
--the CAN baud rate
CAN_baud = 250000
CAN_chan = 0
--format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units])
rpmId = addChannel("RPM", 25, 0, 0, 10000)
tpsId = addChannel("TPS", 25, 0, 0, 100, "%")
fuelTimeId = addChannel("InjectorPw", 25, 2, 0, 30, "ms")
ignId = addChannel("Ignition", 25, 0.1, -20, 100, "deg")
baroId = addChannel("Baro", 1, 1, 0, 105, "kpa")
mapId = addChannel("MAP", 25, 1, 0, 255, "kpa")
lambdaId = addChannel("Lambda", 25, 3, -2, 2, "")
iatId = addChannel("IAT", 25, 1, 0, 255, "F")
tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F")
function rpmFilter(value)
 return value
--format is:
--[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>,
--                                   <adder>, [filter])
CAN_map = {
[0x0CFFF048] = function(data) map_chan(rpmId, data, 0, 2, 1, 0, rpmFilter)
                              map_chan_s(tpsId, data, 2, 2, 0.1, 0)
                              map_chan_s(fuelTimeId, data, 4, 2, 0.01, 0)
                              map_chan_s(ignId, data, 6, 2, 0.1, 0)
               end,
[0x0CFFF148] = function(data) map_chan_s(baroId, data, 0, 2, 0.01, 0)
                              map_chan_s(mapId, data, 2, 2, 0.01, 0)
                              map_chan_s(lambdaId, data, 4, 2, 0.001, 0)
               end,
[0x0CFFF548] = function(data) map_chan_s(iatId, data, 2, 2, 0.1, 0)
                              map_chan_s(tempId, data, 4, 2, 0.1, 0)
    processCAN(CAN_chan)
function processCAN(chan)
    local msg = 0
    repeat
        local id, e, data = rxCAN(chan, 0)
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
        msg = msg + 1
    until id == nil or msg > 100
    if offset + len > #data then return end
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
   local cv = value * mult + add
   setChannel(cid, cv)
function map_chan_s(cid, data, offset, len, mult, add, filter)
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    --adjust for sign
    if value > 32767 then value = value - 65536 end
    setChannel(cid, cv)
initCAN(CAN_chan, CAN_baud)
