RacecapturePro MK3 hardware install
Mounting Orientation
Alternative Mounting
- Example:
- Upside down
- Vertical / on edge
Main Connector
The main connector provides access to all power, sensor and communications connections for the RaceCapture/Pro system.
Power | |
Connection | Color |
12v | Red |
Ground | Black |
Frequency / RPM sensor inputs | |
Blue | Frequency / RPM input 1 |
Blue / White stripe | Frequency / RPM input 2 |
Blue / Green Stripe | Frequency / RPM input 3 |
Blue / Orange Stripe | Frequency / RPM input 4 |
Voltage Reference | |
Yellow | +5v voltage reference |
Analog Sensor Inputs | |
White | Analog Input 1 |
White / Black Stripe | Analog Input 2 |
White / Orange Stripe | Analog Input 3 |
White / Blue Stripe | Analog Input 4 |
White / Gray Stripe | Analog Input 5 |
White / Green Stripe | Analog Input 6 |
White / Red Stripe | Analog Input 7 |
White / Brown Stripe | Analog Input 8 |
General Purpose Input / Output (GPIO) | |
Gray | GPIO 1 |
Gray / White Stripe | GPIO 2 |
Gray / Blue Stripe | GPIO 3 |
Auxiliary Serial Input | |
Purple / White Stripe | Auxiliary RS232 Serial TX |
Purple | Auxiliary RS232 Serial RX |
CAN Bus | |
Orange / Blue Stripe | CAN 1 High |
Orange | CAN 1 Low |
Orange / Green Stripe | CAN 2 High |
Orange / White Stripe | CAN 1 Low |
Plug Connector Type
- Plug Housing: Molex Mini Fit Jr 39012240
- Compatible Pins: Molex 46018-1541 or 46018-1541
- ProTip: a 24 pin Molex harness from a computer power supply can also work as a secondary wiring harness
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
Connection | CAT5 EIA-T568B RJ45 cable |
+12v | Brown |
Ground | Orange/White |
CAN 1 High | Orange |
CAN 1 Low | Green/White |
CAN 2 High | Blue |
CAN 2 Low | Blue/White |
