RacecapturePro MK3 hardware install
Revision as of 04:54, 25 March 2017 by Brentp (talk | contribs) (Sensors)
Mounting Orientation
Alternative Mounting
  • Example:
    • Upside down
    • Vertical / on edge
Main Connector
Power
Connection Color
12v Red
Ground Black
Frequency / RPM sensor inputs
Blue Frequency / RPM input 1
Voltage Reference
Yellow +5v voltage reference
Analog Sensor Inputs
White Analog Input 1
Gray GPIO 1
Gray / White Stripe GPIO 2
Gray / Blue Stripe GPIO 3
Auxiliary Serial Input
CAN Bus
Orange CAN 1 Low
Plug Connector Type
  • Compatible Pins: Molex 46018-1541 or 46018-1541
  • ProTip: a 24 pin Molex harness from a computer power supply can also work as a secondary wiring harness
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
Analog Sensor inputs
Specs
Connecting Sensors
GPIO
Input Mode
Output Mode
Communications
CAN Channels 1 / 2
Auxiliary Serial
