How To Update Firmware
Revision as of 14:55, 5 May 2016 by Rdoherty (talk | contribs)
RaceCapture/Pro MK2
Save your configuration
Alternative method
  • You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
RaceCapture/Pro MK1
Alternatively:
Mac Users
