RaceCapture on Raspberry Pi
Prerequisites
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
  • Via raspi-config tool
  • Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
cd /opt
sudo wget <package URL>
Extract the package
sudo tar -xzvf <downloaded file>
Launch the app
