RaceCapture on Raspberry Pi
Benefits
  • Automatically runs upon power up - no app to launch
  • Hard-wired data connection to RaceCapture - no wireless connection to configure
  • Runs on the bare metal - the RaceCapture app runs without Android or iOS; no other apps competing for resources, or compromising system stability.
  • Overheating resistance - Your typical mobile device requires extra care to prevent damage to it's internal battery and will shut down if overheated. With proper heat-sinking, the Raspberry Pi can bypass these issues.
Experimental
These instructions are for those adventurous race car hackers who know their away around a command line, comfortable working with hardware and want to dig in. The results are pretty great!
We've created a downloadable install package for the RaceCapture app that is as close to self-running as possible on a bone stock Raspbian Jesse image - see the instructions below to start.
Upcoming, we will create a dedicated Raspberry Pi image that you can burn to an SD card and simply boot.
Prerequisites
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
  • Via raspi-config tool
  • Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
cd /opt
sudo wget <package URL>
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
exit 0
