RaceCapture on Raspberry Pi
Benefits
  • Automatically runs upon power up - no app to launch
  • Hard-wired data connection to RaceCapture - no wireless connection to configure
  • Runs on the bare metal - the RaceCapture app runs without Android or iOS; no other apps competing for resources, or compromising system stability.
  • Overheating resistance - Your typical mobile device requires extra care to prevent damage to it's internal battery and will shut down if overheated. With proper heat-sinking, the Raspberry Pi can bypass these issues.
Experimental!
While the results are pretty great, these instructions are currently for those adventurous race car hackers who know their away around a command line, comfortable working with hardware and want to dig in.
Being brand new and officially experimental in nature, we've still wrapped up the RaceCapture App into as close to a self-running installer as possible, that can run on a bone stock Raspberry Pi image - only a few changes are required to the default image.
Getting support
Best place to get support is to share on the forums - we want to hear your successes, questions and ideas.
Hardware Selection
Raspberry Pi
Display
Other displays can work as well, and additional work may be needed to support the screen's touch controller.
If unsure, just pick the Official Raspberry Pi display
Installing Rasbian OS
Installing dependencies
Change the default password
> passwd
Enable WiFi
(Optional) Enable SSH
Install multi-touch tools
Configure memory split
  • Via raspi-config tool
  • Editing /boot/config.txt
> sudo nano /boot/config.txt
gpu_mem=256
cd /opt
sudo wget <package URL>
Extract the package
Launch the app
Launching with Watchdog
killall -9 run_racecapture.sh
Automatic start upon power up
sudo nano /etc/rc.local
exit 0
