ShiftX2
Revision as of 04:19, 18 July 2017 by Brentp (talk | contribs) (→Script)
In the kit you will receive:
  • ShiftX2 module
  • 4 wire pigtail
  • Acrylic enclosure
Assembling the enclosure
Mounting ShiftX2
Pinout
Color Assignment Notes
Red 5-12v Power Connect this to switched ignition power. 0.5A max consumption.
Black CAN High
Yellow CAN Low
White Ground
Power
  • Note: You can use the same circuit for your RaceCapture system so they power up simultaneously.
CAN bus connections
  • Note: You can choose either CAN1 or CAN2 to drive ShiftX2. The CAN bus can be defined in the script you use to control ShiftX2.
Scripts
Disco Lights Demo
Script
sxCan = 1
sxId=0
tickRate=30
sxBright=0
function rndc()
  return math.random(0,255)
function sxOnUpdate()
  for i=0,9,1 do
    r = rndc()
    g = rndc()
    b = rndc()
	sxSetLed(i,1,r,g,b,0)
function sxOnBut(b)
  println('button: ' ..b)
function sxOnInit()
  print('sx onInit')
--ShiftX2 library functions--
  sxTx(10,{i,l,r,g,b,f})
  sxTx(3,{bright})
  sxTx(20,{id,r,g,b,f})
function sxUpdateAlert(id,v)
  sxTx(42,{spl(v),sph(v)})
function sxInit()
  println('config shiftX2')
  sxSetBaseConfig(sxBright)
function sxChkCan()
  id,ext,data=rxCAN(sxCan,0)
function sxProcess()
  sxChkCan()
function sxTx(offset, data)
  sleep(10)
  sxProcess()
sxInit()
Sequential shift light
Script
sxCan = 1
sxId=0
tickRate=30
sxBright=0
function sxOnInit()
  --config shift light
function sxOnBut(b)
---ShiftX2 functions
  sxTx(3,{bright})
function sxInit()
  setBaseConfig(sxBright)
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
Assumptions:
Script
sxCan = 1
sxId=0
tickRate=30
sxBright=0
  --update engine temp alert
  sxUpdateAlert(0, getAnalog(0))
  --update oil pressure alert
  sxUpdateAlert(1, getAnalog(1))
function sxOnInit()
  sxSetAlertThresh(1,0,0,255,0,0,10) --red flash below 15 psi
function sxOnBut(b)
  sxTx(3,{bright})
function sxInit()
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
Script
--implement me
Boost Gauge
Script
--implement me
Only Alerts
  • Left alert for oil pressure
Script
--implement me
ShiftX2 starter script
sxCan = 0
sxId=0
tickRate=30
sxBright=0
function sxOnInit()
function sxOnBut(b)
--Set an individual LED
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value(0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
--End reference
  sxTx(3,{bright})
function sxInit()
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
ShiftX2 CAN bus API
Offset What Value
Offset What Value
Offset What Value
0 Brightness 0 - 100; default = 0 (0=automatic brightness)
1 Automatic brightness scaling (Optional) 0-255; default=51
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Button State
CAN ID: Base + 60
Offset What Value
