<img src="
" width="640"/>
Prerequisites
Get a device Id
Integrated cellular telemetry
Supported devices
- RaceCapture/Apex
- RaceCapture/Pro MK3, MK2, MK1 with integrated telemetry option
Get a SIM card
Which SIM card to get?
USA
Freedom Pop (Recommended)
We currently recommend the $0/month plan from FreedomPop. Based on the AT&T network, it offers the best performance in rural areas across the USA.
AT&T
AT&T is our second recommendation as they have announced affordable plans targeting tablets and other data-only devices.
When you arrive at the store:
- Ask for a $15/month Go-phone plan with data
- Request a full-sized SIM (RaceCapture/Pro) or a micro SIM (RaceCapture/Apex)
- IMEI: usually they will use a default IMEI. If they require one, you can get the IMEI from the system status page
- Let them know that your device does not support 4G LTE (it's a 3.5G module)
- Important note about AT&T and legacy 2.5G modules in RaceCapture/Pro MK2
- Use a carrier that still supports 2G Data, such as T-Mobile
- Upgrade your RaceCapture/Pro MK2 with the 3.5G module
T-Mobile
- Ask for a pre-paid $3/day plan
Global
RaceCapture/Pro MK3 and RaceCapture/Apex uses a world-wide compatible GSM cellular module. Check with your carrier for support. You will also likely need to set a custom APN setting in the telemetry configuration; the carrier will have these APN settings available.
How much data will I need?
- Number of channels enabled
- Sample Rate of channels
Installing the SIM card
RaceCapture/Apex
- Remove the cover from the rear of the enclosure, and insert the SIM card into lower part of the silver card holder (below the SD card position).
RaceCapture/Pro MK3
- Use a pen, stylus or similar press the eject button next to the SIM card slot on the front panel - the card slot will pop out slightly. Manually withdraw it.
- Insert the SIM card into the holder, noting the angled notch. Re-insert with the SIM card facing up and press until the front edge is flush with the face, until you feel the tray seat.
- Important: The card carrier should slide in smoothly, and require just a bit of force to lock in to place. Take care to not force the card in at an angle.
RaceCapture/Pro MK2
- Use a pen, stylus or similar press the eject button next to the SIM card slot - the card slot will pop out slightly. Manually withdraw it.
- Insert the SIM card into the holder, noting the angled notch. Re-insert with the SIM card facing down and press until the front edge is flush or just below the surface of the enclosure face, and you feel the tray seat.
SIM adapters
Attach cellular antenna
- Important: Do not over-tighten antenna connection
Antenna placement
Telemetry Configuration
- Launch the RaceCapture app and connect to your RaceCapture hardware.
- Once it connects, navigate to Setup
Enable Telemetry
- Under Setup, select Telemetry section.
- In the Device ID field, enter the Device Id provided by your podium.live account.
Enable Cellular
- if your carrier is not listed, select other and specify the APN settings provided by your wireless company.
- List of APNs worldwide
Write Configuration
- Write your configuration back to the RaceCapture unit
- It's recommended you also save your configuration to a file for safe keeping.
Testing and Verification
Powering up
3.5G module
- Applies to: RaceCapture/Apex, RaceCapture/Pro MK3, MK2 (with 3.5G option)
2.5G module
- Applies to: RaceCapture/Pro MK2 (with 2.5G option), MK1
Watching for telemetry
- Note: You can also edit and rename this event.
LED indicators
RaceCapture/Apex
- Observe the blue telemetry status indicator on the top of the unit.
RaceCapture/Pro MK3
- Observe the blue telemetry status indicator on the front panel of the unit.
RaceCapture/Pro MK2
- When connected and transmitting, the top-right green telemetry LED will flash rapidly and steadily.
- Missing / Incorrect Device Id: Ensure RaceCapture/Pro is configured with a Device ID provided by your Podium account.
- Cellular disabled: Ensure the the Cellular option is set to on in the Wireless settings under Setup.
- Expired SIM card: Make sure your SIM card has enough credit to enable data.
- Poor signal quality: Ensure adequate coverage in the area.
- Loose / incorrect antenna connection: Ensure the antenna is correctly torqued to 4-6 inch/lbs (just beyond finger-tight) and connected to the correct antenna port.
- No 12v power (2.5G cellular only) The 2.5G internal telemetry module requires external 12v (via green terminal block or OBD-II cable)
- Note: 3.5G cellular telemetry can be powered by USB.
Debugging Cellular activity
RaceCapture App Telemetry
This section steps you through setting up telemetry via the RaceCapture App.
Supported devices
- All versions of RaceCapture hardware
Enable Telemetry
Disable Cellular
- Select the Wireless section
- Ensure Cellular telemetry is disabled, if the option is available.
Write Configuration
Verify Telemetry
- Dim Green Not active
- Red Connection Error
- Missing / Incorrect Device Id: Ensure the Device ID provided by your Podium account is correctly set.
- App Telemetry disabled: Ensure the "Send Telemetry" option is enabled under the RaceCapture App preferences.
- Cellular enabled: If the Cellular option is available under the Wireless settings under Setup, ensure it is set to off - otherwise the system will assume you want to broadcast via the internal cellular module.
- No data available on plan: Verify internet connectivity on the phone or tablet using a simple browser connectivity test.
