AnalogX
Revision as of 01:12, 7 January 2018 by Brentp (talk | contribs) (→Sensor connections: fixed wiring order)
In the kit you will receive:
  • AnalogX module
Feature Description
DAC resolution 12 bit SAR
Input voltage protection 100v
Power input 9 - 15volts, protected to 40v (intermittent)
Weight 6 grams
Power and CAN
Color Assignment Notes
Red 9-15v Power Connect this to switched ignition power. 0.25A max consumption.
Black CAN High
Orange CAN Low
Blue Ground
Sensor connections
Brown Analog 1 input 0-5v input
Pink Analog 2 input 0-5v input
Purple Analog 3 input 0-5v input
Blue Analog 4 input 0-5v input
Yellow Voltage reference output 5v @ 0.5A
Black Ground reference
AnalogX CAN bus API
Adjusting Base ID
Closed Open 0xE4700 (935680)
Open Closed 0xE4800 (935936)
Open Open 0xE4900 (936192)
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Configuration Group 1
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
5 Reserved
6 Reserved
7 Reserved
Address
Offset What Value
1 Reserved
2 Reserved
3 Reserved
4 Reserved
Sample Broadcast
Scaling and Data format
  • Scaling: 0-5000mV
  • Data format: Little Endian
Address
  • CAN ID: Base + 20
Offset What Value
0 Channel 1, low byte
1 Channel 1, high byte
2 Channel 2, low byte
3 Channel 2, high byte
4 Channel 3, low byte
5 Channel 3, high byte
6 Channel 4, low byte
7 Channel 4, high byte
