PodiumConnect
Getting Started
Installing the app
Install the beta 1.12.0 app from http://podium.live/software (Windows or OSX)
Android: Follow this link to get the Beta 1.12.0 app: https://play.google.com/apps/testing/com.autosportlabs.racecapture
First time setup wizard
Recommend setting up with windows/OSX to start.
- Plug RaceCapture into the USB port on your computer and launch the app.
- The app will present you with a startup wizard. Follow the steps.
When presented with the presets, Select AiM as your preset.
Select your favorite Tracks
- Note: Only select the one track configuration per venue.
Create an account on Podium
Create an account on Podium http://podium.live - then follow the steps to create a Device. Note the Device ID provided, you will need to enter it into the wizard.
Select your cell provider
Select the cellular provider you will use.
Verifying connectivity with data system
- Connect the integration cable between your data system and PodiumConnect.
- Navigate to the dashboard view in the app, and press the left arrow in the lower left of the screen, until you see a page with many channels listed.
- Verify you are seeing data in the GPS and sensor channels flowing from the data system.
Testing Telemetry
Install your SIM card
Insert your SIM card by popping the drawer
- Slide the SIM card tray back into the drawer, ensuring you engage the drawer slot carefully. Press until the drawer seats.
Testing Telemetry
- Refresh this page when telemetry is broadcasting; you will see an "Ad Hoc event" listed.
