Megasquirt CAN
Channels enabled:
  • Engine RPM (RPM)
  • Throttle Position (TPS)
  • Air/Fuel Ratio (AFR)
Megasquirt Wiring
RaceCapture/Apex
Use the CAN High and Low connections from either CAN1 or CAN2. Typically CAN1 is used, so you would use CAN 1 High and CAN 2 HIgh. RaceCaptureApex can bus pinout.png
RaceCapture/Pro MK3
Use the CAN High and Low connections from either CAN1 or CAN2 on the 24 pin Molex harness. Typically CAN1 is used, so you would use CAN 1 High and CAN 2 HIgh. RaceCapture Pro MK3 Molex CAN pinout.png
RaceCapture/Pro MK2 and MK3 RJ45
You can use a standard CAT-5 ethernet cable with RJ45 connectors to integrate with RaceCapture/Pro MK2 and MK3
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
  • Note: If you have RaceCapture/Pro powered through the terminal block and grounded at the same location, all you need to wire are the two CAN ligh/CAN low connections. You do not need to separately connect ground and power via the RJ45 port.
Microsquirt
Megasquirt 2 V3
  • CAN High - DB37 Pin 3 (SPR1)
  • CAN Low - DB37 Pin 4 (SPR2)
MS3 Pro
  • CAN High: Pin 34
  • CAN Low : Pin 33
Photos
Enable Megasquirt Dashboard Mode
Megasquirt Preset
References
