PodiumConnect RaceTechnology
Revision as of 00:30, 7 May 2018 by Brentp (talk | contribs) (Created page with "=Choosing Preset= During the setup Wizard, you would have selected the RaceTechnology DL1 integration, which includes: * GPS Position * Speed * Battery voltage * RPM * AccelX...")
Choosing Preset
  • GPS Position
  • Speed
  • Battery voltage
  • RPM
  • AccelX (Longitudinal Acceleration)
  • AccelY (Lateral Acceleration)
  • Altitude
Connecting your DL1 system
Connect PodiumConnect to the DL1 using the included integration cable, plugging the DB9 connector into your DL1 while plugging the other end into PodiumConnect.
Connect the red and black pigtail connectors to 12v and ground, respectively.
Verifying telemetry data
Power up both the DL1 and PodiumConnect, and then connect the RaceCapture app to PodiumConnect via USB (desktop Windows or OSX) or WiFi (Android or iOS).
Go to the Dashboard page, then navigate using the arrows to the Raw Channels view. Verify you see data flowing from the DL1, including GPS Latitude, Longitude, Speed if your DL1 has a GPS lock.
Customizing Channel Mappings
