AnalogX
In the kit you will receive:
- AnalogX module
- 4 wire power and CAN pigtail
- 6 wire analog sensor input pigtail
- 1" shrink tube for installation
Compatible Sensors
- Note - RaceCapture's CAN mapping features currently only supports sensors with a linear (straight-line) response. Sensors with a curved response, such as thermistors, will not work with the built-in direct CAN mapping. We recommend using a temperature sensor with a linear response, such as the Texense Liquid Temperature Sensor or similar.
Setting CAN baud rate
Selecting the AnalogX preset
Select the channel
Edit the conversion formula
Example: 0.5 - 4.5v 150 PSI oil pressure sensor
0.5v = 0 PSI 4.5v = 150 PSI
Therefore, 150 PSI / 4000mV = 0.0375 PSI/mV, and the resulting formula is RAW * 0.0375 - 18.75
AiM, MoTeC and other systems
No CAN data
- Verify the CAN baud rate is compatible with the AnalogX configuration (500K by default, 1MB with jumper modified)
- Verify your CAN bus termination is correct. AnalogX is terminated by default.
Basic mapping test
- Go into the software for the receiving system, and set the CAN formula to multiply by 1 and add 0 and divide by 1 , and update the software settings.
If you can verify received millivolt value equals the measured voltage at the AnalogX input, then you know the correct value is being transmitted to the system. Consult the sensor manufacturer and the system to determine the proper mapping of the sensor you are using.
Feature | Description |
Analog input voltage range | 0 - 5v |
DAC resolution | 12 bit SAR |
Sample output format | 0 - 5000mV |
Input impedance | Greater than 10 Meg Ohm |
Input voltage protection | 100v |
Pullup resistor | Optional on-board 2.2K pullup resistor for each channel (jumper enabled) |
Power input | 9 - 15volts, protected to 40v (intermittent) |
Weight | 6 grams |
Dimensions | 0.72" x 1.93" (18.3mm x 48.7mm) |
CAN baud rate | 500K and 1M, jumper configurable |
Address Space | 4 separate address spaces allows up to 4 AnalogX modules to operate on the same CAN network. (jumper configurable) |
Source Code
Power and CAN
Color | Assignment | Notes |
Red | 9-15v Power | Connect this to switched ignition power. 0.25A max consumption. |
Black | CAN High | |
Orange | CAN Low | |
Blue | Ground |
Sensor connections
Brown | Analog 1 input | 0-5v input |
Pink | Analog 2 input | 0-5v input |
Purple | Analog 3 input | 0-5v input |
Blue | Analog 4 input | 0-5v input |
Yellow | Voltage reference output | 5v @ 0.5A |
Black | Ground reference |
CAN termination
AnalogX CAN bus API
Adjusting Base ID
Closed | Closed | 0xE4600 (935424) |
Closed | Open | 0xE4700 (935680) |
Open | Closed | 0xE4800 (935936) |
Open | Open | 0xE4900 (936192) |
Address
Offset | What | Value |
0 | Channel Count | Total number of channels on device |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Major Version | Firmware Major Version Number |
6 | Minor Version | Firmware Minor Version Number |
7 | Patch Version | Firmware Patch version number |
Configuration Group 1
Address
0 | Sample Rate | Rate to report sensor values ( 1 - 255Hz). Default sample rate is 50Hz. |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
5 | Reserved | |
6 | Reserved | |
7 | Reserved |
Address
0 | Current Sample Rate | 1 - 255Hz |
1 | Reserved | |
2 | Reserved | |
3 | Reserved | |
4 | Reserved | |
Sample Broadcast
Scaling and Data format
- Scaling: 0-5000mV
- Data format: Little Endian
Address
- CAN ID: Base + 20
0 | Channel 1, low byte | |
1 | Channel 1, high byte | |
2 | Channel 2, low byte | |
3 | Channel 2, high byte | |
4 | Channel 3, low byte | |
5 | Channel 3, high byte | |
6 | Channel 4, low byte | |
7 | Channel 4, high byte |
