RCP stimulator
Revision as of 03:50, 6 January 2019 by Brentp (talk | contribs) (→Format)
RS232 serial output
Baud Rate
Baud rate is 115200, 8N1
Format
  • Timestamp in milliseconds
  • Channel 1 value (0-10000)
  • Channel 2 value (0-10000)
  • Channel 3 value (0-10000)
  • Channel 4 value (0-10000)
  • Value echoed back from received data
initSer(6, 115200, 8, 0, 1)
  --write something to be echoed back on last line
  writeSer(6, 'echo')
  value = readSer(6, 1000)
    print('read value: ' ..value)
38817 ,0,0,0,0
39017 ,0,0,0,0
39217 ,0,0,0,0
39417 ,0,0,0,0
39617 ,0,0,0,0
39817 ,0,0,0,0
40017 ,0,0,0,0
40217 ,0,0,0,0
40417 ,0,0,0,0
40617 ,0,0,0,0
40817 ,0,0,0,0
41017 ,302,0,0,0
41217 ,1110,0,0,0
41417 ,1940,0,0,0
41617 ,1943,0,0,0
41817 ,1943,0,0,0
42017 ,1940,0,0,0
42217 ,1942,717,0,0
42417 ,1935,1321,0,0
42617 ,1935,1363,0,0
42817 ,1938,1363,0,0
43017 ,1940,1363,0,0
43217 ,1937,1362,795,0
43417 ,1938,1360,1478,0
43617 ,1939,1362,1473,0
43817 ,1938,1360,1477,0
44017 ,1937,1358,1477,0
44217 ,1938,1360,1476,513
44417 ,1934,1359,1477,1482
44617 ,1938,1360,1474,1489
