RCP stimulator
Revision as of 04:44, 6 January 2019 by Brentp (talk | contribs) (→‎GPIO)
GPIO
Input Mode
Configure your GPIOs under Setup/GPIO for input mode, and then configure a gauge on the dash to observe the state.
Output mode and Demo script
  • Note Ensure the GPIO ports are in output mode under RaceCapture Setup / GPIO.
--Demo script for toggling LEDs on stimulator board
--GPIOs must be set for output mode in RaceCapture Setup
setTickRate(1)
count = 0
  --toggle LEDs
  local state = count % 2
  setGpio(0, state == 0)
  setGpio(1, state == 0)
  setGpio(2, state == 0)
  count = count + 1
RS232 serial output
Baud Rate
Baud rate is 115200, 8N1
Format
  • Timestamp in milliseconds
  • Channel 1 value (0-10000)
  • Channel 2 value (0-10000)
  • Channel 3 value (0-10000)
  • Channel 4 value (0-10000)
  • Value echoed back from received data
initSer(6, 115200, 8, 0, 1)
  writeSer(6, 'echo')
  value = readSer(6, 1000)
    print('read value: ' ..value)
352023 ,0,0,0,0,echo
352223 ,0,0,0,0,echo
352423 ,0,0,0,0,echo
352623 ,0,0,0,0,echo
352823 ,0,0,0,0,echo
353023 ,0,0,0,0,echo
353223 ,275,0,0,0,echo
353423 ,1680,0,0,0,echo
353623 ,1680,0,0,0,echo
353823 ,1680,0,0,0,echo
354023 ,1672,0,0,0,echo
354223 ,1697,1181,0,0,echo
354423 ,1699,2666,0,0,echo
354623 ,1704,2649,0,0,echo
354823 ,1706,2656,0,0,echo
355023 ,1692,2647,0,0,echo
355223 ,1728,4554,0,0,echo
355423 ,1724,4595,0,0,echo
355623 ,1741,4588,0,0,echo
355823 ,1753,4590,1199,0,echo
356023 ,1750,4588,1323,0,echo
356223 ,1755,4588,4730,0,echo
356423 ,1750,4588,4984,0,echo
356623 ,1758,4586,4981,0,echo
356823 ,1750,4583,4959,1299,echo
357023 ,1758,4586,4964,4129,echo
357223 ,1758,4588,4947,4473,echo
357423 ,1753,4586,4957,5269,echo
357623 ,1753,4586,4957,5768,echo
