ShiftX3
In the kit you will receive:
- ShiftX3
- 2 #6 screws for surface mounting
Dimensions
Connection and Installation
Mounting ShiftX3
- RJ45 Splitter
- RJ45 network cable
OBDII Cable integration
OBDII installation is plug and play:
Non OBDII installation
RJ45 power cable for ShiftX3
ShiftX3 connection | RaceCapture Connection | CAT5 EIA-T568B RJ45 cable |
Red | +12v | Brown |
White | Ground | Orange/White |
No Connection | CAN 1 High | Orange |
No Connection | CAN 1 Low | Green/White |
Black | CAN 2 High | Blue |
Yellow | CAN 2 Low | Blue/White |
CAN termination is enabled by default. To disable termination, cut the CAN Term jumper on the bottom of ShiftX3.
Scripts
Disco Lights Demo
Script
setTickRate(30) -- Set configuration. Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, bright,sxAutoBrightScaling,orientInverted) function rndc() return math.random(0,255) end function onTick() for i=0,9,1 do r = rndc() g = rndc() b = rndc() sxSetLed(i,1,r,g,b,0) end sxSetDisplay(0, math.random(0,9)) end
Sequential shift light
Script
setTickRate(30) -- Set ShiftX3 configuration -- Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, 0, 61, 0) --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, linear style, 0 - 7000 RPM range sxSetLinearThresh(0,0,3000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6500 RPM function onTick() sxUpdateLinearGraph(getChannel("RPM")) end
Assumptions:
- Engine Temperature on the 1st alert LED, connected to first analog channel
- Oil Pressure on the 2nd alert LED, connected to second analog channel
Script
setTickRate(30) -- Set ShiftX3 configuration -- Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar) sxSetConfig(1, 0xE4600, 0, 61, 0) --config shift light sxCfgLinearGraph(0,0,0,7000) --left to right graph, linear style, 0 - 7000 RPM range sxSetLinearThresh(0,0,3000,0,255,0,0) --green at 3000 RPM sxSetLinearThresh(1,0,5000,255,255,0,0) --yellow at 5000 RPM sxSetLinearThresh(2,0,6000,255,0,0,10) --red+flash at 6500 RPM --configure first alert (right LED) as engine temperature (F) sxSetAlertThresh(0,0,205,255,255,0,0) --yellow warning at 205F sxSetAlertThresh(0,1,225,255,0,0,10) -- red flash at 225F --configure second alert (left LED) as oil pressure (PSI) sxSetAlertThresh(1,0,0,0,0,255,10) --red flash below 15 psi sxSetAlertThresh(1,1,15,255,255,0,5) --yellow flash 15-20 PSI sxSetAlertThresh(1,2,20,0,0,0,0) --above 20, no alert function onTick() --update RPM sxUpdateLinearGraph(getChannel("RPM")) --update engine temp alert sxUpdateAlert(0, getChannel("EngineTemp")) --update oil pressure alert sxUpdateAlert(1, getChannel("OilPress")) end
Script
-- Predictive time visualizer -- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2 sxCan = 1 -- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut) sxId=1 --how often ShiftX3 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 --save best lap time bestTime = 0 function sxOnUpdate() local predTime = getPredTime() local timeDiff = (bestTime - predTime) * 60 -- rail values timeDiff = math.max(timeDiff, -10) timeDiff = math.min(timeDiff, 10) --scale values from +/- 10 sec to a 0-200 scale timeDiff = (timeDiff + 10) * 10 sxUpdateLinearGraph(timeDiff) --update best lap time if an updated lap time is available local lastLapTime = getLapTime() if lastLapTime < bestTime or bestTime == 0 then bestTime = lastLapTime end end function sxOnInit() --config shift light sxCfgLinearGraph(1,0,0,200) --center-out graph, linear style, +/- 10.0 seconds in 0.1 sec resolution sxSetLinearThresh(0,0,0,255,0,0,0) --red if you're falling behind best lap sxSetLinearThresh(1,0,80,0,0,255,0) --blue if you're close to best lap sxSetLinearThresh(2,0,110,0,255,0,0) --green if you're beating best lap end function sxOnBut(b) --if button is pressed, reset the best lap time bestTime = 0 end ---ShiftX3 functions function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) if v ~= nil then sxTx(42,{spl(v),sph(v)}) end end function sxInit() println('config ShiftX3') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) setTickRate(tickRate) sxInit()
Boost Gauge
Assumptions
- MAP sensor channel is on the first Analog channel, and reads in KPa - typically 0-255. You can also connect this to the MAP reading on OBDII (PID 11)
Script
-- What CAN bus ShiftX3 is connected to. 0=CAN1, 1=CAN2 sxCan = 1 -- 0=first ShiftX3 on bus, 1=second ShiftX3 (if ADR1 jumper is cut) sxId=1 --how often ShiftX3 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 function sxOnUpdate() local map = getAnalog(0) --MAP sensor in KPa --convert to PSI boost local boost = math.max(map - 100, 0) * .145038 sxUpdateLinearGraph(boost) println(map ..' ' ..boost) end function sxOnInit() --config shift light sxCfgLinearGraph(0,0,0, 20) --left to right graph, linear style, 0 - 20 PSI boost sxSetLinearThresh(0,0,0,0,255,0,0) --green starting at no boost sxSetLinearThresh(1,0,10,255,255,0,0) --yellow starting at 10 PSI boost sxSetLinearThresh(2,0,15,255,0,0,10) --red+flash at 15 PSI boost end function sxOnBut(b) --called if the button state changes println('button: ' ..b) end ---ShiftX3 functions function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) if v ~= nil then sxTx(42,{spl(v),sph(v)}) end end function sxInit() println('config ShiftX3') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('ShiftX3 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
Only Alerts
- Left alert for oil pressure
Script
ShiftX3 CAN bus API
Offset | What | Value |
1 | Automatic brightness scaling (Optional) | 0-255; default=51. adjust this value to adjust the relative gain of the built-in light sensor when in automatic brightness mode. |
Set Display
CAN ID: Base + 50
Set Discrete LED
CAN ID: Base + 10
2 | Red | 0 - 255 |
3 | Green | 0 - 255 |
4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
1 | Red | 0 - 255 |
2 | Green | 0 - 255 |
3 | Blue | 0 - 255 |
Set Alert Threshold
CAN ID: Base + 21
1 | Threshold ID | 0 - 4 |
2 | Threshold (low byte) | |
3 | Threshold (high byte) | |
4 | Red | 0 - 255 |
5 | Green | 0 - 255 |
6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
1 | Value (low byte) | |
2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
2 | Low Range (low byte) | |
3 | Low Range (high byte) | |
Set Linear Graph Threshold
CAN ID: Base + 41
0 | Threshold ID | 0 - 4 |
4 | Red | 0 - 255 |
CAN ID: Base + 42
0 | Value (low byte) | |
1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
