ShiftX3
Revision as of 06:35, 11 January 2019 by Brentp (talk | contribs) (Script)
In the kit you will receive:
  • ShiftX3
Dimensions
Connection and Installation
Mounting ShiftX3
  • RJ45 Splitter
  • RJ45 network cable
OBDII Cable integration
OBDII installation is plug and play:
  • Plug the OBDII cable into the CAN hub
Non OBDII installation
RJ45 power cable for ShiftX3
Red +12v Brown
White Ground Orange/White
Black CAN 2 High Blue
Yellow CAN 2 Low Blue/White
CAN termination is enabled by default. To disable termination, cut the CAN Term jumper on the bottom of ShiftX3.
Scripts
Disco Lights Demo
Script
setTickRate(30)
-- Set configuration. Parameters: can bus (0=CAN1, 1=CAN2), base address, brightness, auto brightness scaling, orientation (0=normal, 1=display above LED bar)
sxSetConfig(1, 0xE4600, bright,sxAutoBrightScaling,orientInverted)
function rndc()
  return math.random(0,255)
  for i=0,9,1 do
    r = rndc()
    g = rndc()
    b = rndc()
    sxSetLed(i,1,r,g,b,0)
Sequential shift light
Script
setTickRate(30)
-- Set ShiftX3 configuration
sxSetConfig(1, 0xE4600, 0, 61, 0)
--config shift light
Assumptions:
Script
setTickRate(30)
  --update RPM
  --update engine temp alert
  --update oil pressure alert
Script
-- Predictive time visualizer
--save best lap time
bestTime = 0
setTickRate(30)
  -- rail values
  sxUpdateLinearGraph(timeDiff)
Boost Gauge
Assumptions
  • MAP sensor channel is on the first Analog channel, and reads in KPa - typically 0-255. You can also connect this to the MAP reading on OBDII (PID 11)
Script
setTickRate(30)
  local map = getChannel("MAP")
  --convert to PSI boost
  sxUpdateLinearGraph(boost)
Only Alerts
  • Left alert for oil pressure
Script
--implement me
ShiftX3 CAN bus API
Offset What Value
Offset What Value
Offset What Value
Set Display
CAN ID: Base + 50
Offset What Value
0 Digit index 0 (must be 0)
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Button State
CAN ID: Base + 60
Offset What Value
