Hard rev limiter 1.2.0
Revision as of 07:50, 17 April 2008 by Brentp (talk | contribs) (Board)
General Information
Theory of Operation
Schematics
Board
Assembling the kit
Tools you will need
Parts Inventory
Bill of materials
Part Number Description
U1 FDS6681Z P-Channel Mosfet
R1-R10 180 ohm, 1W SMT 2412
Q1 SMBT2907A PNP transistor
R11 10K 1206 SMT
R12 100K 1206 SMT
Parts before assembly
Surface mount soldering
Soldering lead-less surface mount components typically involves tacking one lead down to the board to fix it in place and then working on the remaining leads. With the smaller components, be careful to not apply excessive heat- just enough is needed to flow the solder into the joint. Excessive heat, at minimum, will cause small parts to slide off the pads, and at worst, can destroy them.
Installing the parts
Preparing the solder pads
Prepping the solder pads before component installation
Closeup of solder preparation
Installing the power resistors
Soldering power resistors
Installing supporting components
Install Q1. Pick up the transistor across it's width and bring it into position over the pad where you previously applied the solder blob. Heat up the pad so the solder flows over the transistor's lead. Be careful to minimize heat exposure on this small part.
Soldering Q1
Once the transistor is tacked into position, apply a small amount of solder to to the other two pads of Q1.
Soldering the 1206 components. Use minimal heat here!
Closeup detail
Installing power transistor
Tacking down Q1 before soldering the remaining pins
Install terminal block
Install the terminal blocks with the wire entry point pointing away from the board.
Final Inspection
Completed Hard Rev Limiter
Installing the Hard Rev Limiter
Wiring diagram
Physical Installation
It's up to the user to determine how to install the rev limiter module, and a variety of possibilities exist.
One consideration is heat- Since the resistor array generates heat when rev-limiting is active, ambient temperature and air flow across the module will affect the duty-cycle of the unit- meaning how often and long you'll be able to be 'on' the rev-limiter.
Freestanding installation
Integrating into the MJLJ enclosure
The board has been sized to fit the MJLJ enclosure, and it it possible to slide in the board into one of the extra slots of the case.
With this approach, several wiring possibilities exist:
  • Cut a hole in the end plate, externally expose the connectors and wire the module externally.
  • Cut a hole in the end plate, externally expose the +12v and coil pack connectors, but connect the ground and trigger with jumpers to the inside of the case.
  • Most ambitious: wire everything internally:
    • Jumper GND connection to MJLJ GND
    • Jumper +12V connection to MJLJ +12V
    • Jumper trigger input to REV_LIMIT output on MJLJ board
    • Cut the REV_LIMIT trace on the MJLJ board running from the ULN2003 to the REV_LIMIT connector pin. The REV_LIMIT pin will now be the new COIL power supply.
    • Use a thicker gauge wire (14 - 12ga) for MJLJ +12V power, if necessary: This will now feed current to the coil in addition to powering the MJLJ electronics.
    • Connect the Rev limit COIL output to REV_LIMIT pin on MJLJ connector.
